Ethanol gas
Old Feb 21, 2013 | 5:40 PM
fullswedge's Avatar
Default Ethanol gas
Good day;
I have a 5.3 in my 2006 chev. should i have any worries about running e-10 e-15 gas? other than the poor fuel mileage?
Thanks, Bill..
Old Feb 21, 2013 | 6:13 PM
country_09's Avatar
Most stations around here run a e10 blend and I haven't seen any bad effects of it except for a lil loss I'm mpg. I you have a station that has no ethanol blend in their gas then I'd go there
Old Feb 21, 2013 | 6:36 PM
fullswedge's Avatar
Thanks, the truck seems to be running ok, except for the poor mpg. i do have a couple of stations around with no ethanol...4.25 a gal...
Old Feb 21, 2013 | 9:06 PM
cleveland63b's Avatar
shouldnt have any issues if you keep up on your maintenance
Old Feb 22, 2013 | 3:05 PM
I have read a little on the subject but am no expert. imo i wouldn't go over 10% unless your are flex fuel compatible. Ethanol in to high concentration will corrode the pump, injectors, metal lines not designed for ethanol blends.
Old Feb 22, 2013 | 3:33 PM
kevinkpk's Avatar
If you can stay away from it, do so. I get 20% more from regular gas. Ethanol is a blend of alcohol, and enthane. I have worked at the city of Russell Ks they generate thier own power, sell steam to the ethanol plant next to it. It in essence is a brewery that makes ethanol for a blend. As tech2 stated this is an alcohol blend, it can cause problems over time with it. I've seen stations advertise 10 -15% ethanol.
bill64
11
Feb 20, 2012 12:01 PM
Rescue30
Jul 6, 2010 3:48 PM
JoeALVES
Dec 23, 2009 4:38 PM
sweethoneybee
Feb 10, 2008 11:57 AM
mossimo
Jan 29, 2008 7:45 PM
