floating gas gauge
Old Oct 16, 2007 | 12:45 AM
bwaddell's Avatar
Default floating gas gauge
What would cause your gas gauge to float when your truck is in park and your idling. PLEASE HELP!!!!!!!!!!!!!!!!
Old Oct 17, 2007 | 10:36 AM
biggame's Avatar
Default RE: floating gas gauge
I have a issue that is similar. When my 2001 5.3 Z71 is totally full on gas it will drop totally empty and the gas light comes on. Then if I put into drive or hit a bump it comes back to full. It only happens when it is full. Strange,
Old Oct 17, 2007 | 6:01 PM
p.hinds's Avatar
replace the level sensor in the fuel tank
Old Oct 19, 2007 | 5:32 PM
Kevin's Avatar
drop tank, remove and replace float, pump, and sensor.
Old Oct 19, 2007 | 5:49 PM
jimmydaleo's Avatar
Might be easier and cheaper to get a whole sending unit. should be one piece. find part number and comparable models used. might get ebay or junk yard
Old Oct 19, 2007 | 11:50 PM
bwaddell's Avatar
hey fellas, i think i just need to get a new fuel pump and problem solved right.
[/align]
Old Oct 19, 2007 | 11:55 PM
Kevin's Avatar
its in the tank
Old Oct 20, 2007 | 12:00 AM
bwaddell's Avatar
dont quite follow you
[/align]
Old Oct 20, 2007 | 12:03 AM
Kevin's Avatar
fuel pump is the "sender" unit. it is located inside the fuel tank . that is where the float that measures your fuel level is attached.
Old Oct 20, 2007 | 12:12 AM
bwaddell's Avatar
i get that
[/align]
