flowmaster drone
Old Feb 26, 2011 | 8:10 AM
rayfry's Avatar
Default flowmaster drone
I installed a series 40 flowmaster muffler and cat back dual exhaust on my 2004 silverado 5.3. The muffler has 1 inlet and then 2 outlets. The drone in the cab at lower rpm's is deafening. The truck sounds great outside but in the cab the drone is unbearable. Any suggestions without replacing the whole exhaust system?
Old Feb 26, 2011 | 8:45 AM
JK23112's Avatar
I have had Flowmasters (true duals from the cats on back) on my truck since last spring, but mine are the "50" Series. I thought the 40 ones were too loud and the 70 Series was too quiet.
Short of going to a 50 Series, I guess you should either live with it or install a louder stereo system in your truck.
Old Feb 26, 2011 | 8:50 AM
rayfry's Avatar
thanks for the reply..what about installing a heat shield on the muffler to direct the sound down and away from the cab
Old Feb 26, 2011 | 8:56 AM
JK23112's Avatar
Don't know about that.....but perhaps someone at a muffler shop might be of some assistance.
Old Feb 26, 2011 | 9:00 AM
rayfry's Avatar
ok thanks..I know summit sells a heat shield for flowmasters.
Old Feb 26, 2011 | 11:27 AM
ToooTall1's Avatar
Does your exhaust extend out the back to the bumper or just a short pipe turning down at the muffler. The noise is just defening at the muffler in the cab w/o pipes but with pipes out the rear their Great sounding. Have the same muffler but going out back and sounds great at idle and under power, plus gained 3mpg from stock exhaust. Not true duals but good for me.
Old Feb 26, 2011 | 4:27 PM
rayfry's Avatar
No my pipes go out to the rear bumper but the rumble in the cab is bad.
Old Feb 27, 2011 | 2:44 AM
s34n's Avatar
talk to your local muffler shop about having them install a resonator. i had one installed on my 04 1500 with the 40 series there was definitely a noise difference between having the resonator and not having one. if you want to quiet the noise down, short of installing a new muffler out, check this alternative out. good luck
Old Feb 27, 2011 | 12:00 PM
rayfry's Avatar
thanks for that tip, i'll speak to my installer
ratherplaythanwork
Jul 18, 2011 8:50 PM
Aquarius14
May 14, 2008 6:34 AM
jsm
Mar 10, 2008 7:06 PM
71cuda
Feb 18, 2007 11:46 PM
