Front End Shaking
Old Jun 20, 2014 | 8:21 AM
Coach44L's Avatar
Default Front End Shaking
2000 silverado. When I hit rough road or even the larger reflectors, with my right front tire it will shake violently. I felt for play in tire to check for bad wheel bearing, but it seems ok. Could a shock cause this? Any ideas?
Old Jun 20, 2014 | 9:13 AM
old dog's Avatar
a shock just keep's the tire in contact with the road after a impact ,usually old worn out shock they will let the tire violently loose contact and hop up and down after hitting a pot hole or similar item,even hitting the brake's.
Old Jun 21, 2014 | 1:20 AM
Earth Rider's Avatar
My 99 Escalade is doing the same thing when a pot hole or any bump is hit. It causes a severe shake in steering wheel(left & right ringing or oscilation) that continues for 1 to 2 vehicle lengths. I suspect the shocks are at the end of their service life and are causing the problem. Stabilizer links are new so I don't think it's the front stabilizer bar. Tie rod ends are ok as well as the ball joints. I was going to try new shocks in the near future to see if they are the issue.
Old Jun 22, 2014 | 8:37 PM
2kflhr's Avatar
Could be a pitman arm has gone south.
Old Jun 22, 2014 | 10:31 PM
Coach44L's Avatar
Default It was a bad shock!!
It was a bad shock! It rides great now. Thanks all!
robby Joe
31
Oct 25, 2024 10:23 AM
schuey59
Mar 18, 2012 7:15 PM
chazwel
Jan 21, 2012 5:12 PM
Brianabby88
Oct 15, 2011 8:39 PM
Kal4438
Sep 27, 2011 11:10 AM
