Fuel Filter
Warpig6,
I believe the filter is along the frame on the drivers side. There will be pressure built up in the line so, be careful when you loosen it.
Good Luck ,Dondobe
Good Luck ,Dondobe
If you want to relive the pressure on the fuel rail to the injectors (be careful) their is a valve stem used to bleed air out of the system, just hit that like you are letting air out of a tire. The filter should be on the inside of the ds frame rail, (like said above)Or you can crack the line slowly and watch your eye's.
ZX11OOF1,
Thanks! I knew that most were located on the drivers side (like the one I changed on my old Chevy S-10), but I couldn't find it even after the suggested posts...no wonder!
Semper Fi,
Warpig6
Semper Fi,
Warpig6
mltc78
August 22nd, 2018 7:53 PM
silverado 1500 2001
September 14th, 2014 7:41 PM
DeHartShadow
October 22nd, 2013 10:52 AM
