Fuel Filter
Old Feb 24, 2007 | 4:38 PM
Warpig6's Avatar
Default Fuel Filter
Where is the fuel filter on a 2004 Chevy Silverado Ext Cab 4.8litre located?
Old Feb 24, 2007 | 4:54 PM
Dondobe's Avatar
Default RE: Fuel Filter
Warpig6,
I believe the filter is along the frame on the drivers side. There will be pressure built up in the line so, be careful when you loosen it.
Good Luck ,Dondobe
Old Feb 24, 2007 | 7:19 PM
VAhorseman's Avatar
I recently looked at fuel filters. They do go in the line and are usually on the frame on the drivers side.
Old Feb 25, 2007 | 6:33 AM
kcb37's Avatar
If you want to relive the pressure on the fuel rail to the injectors (be careful) their is a valve stem used to bleed air out of the system, just hit that like you are letting air out of a tire. The filter should be on the inside of the ds frame rail, (like said above)Or you can crack the line slowly and watch your eye's.
Old Feb 25, 2007 | 11:55 AM
ZX1100F1's Avatar
On your particular truck there is no replaceable fuel filter, there is a life-time filter located on the tank.
Old Feb 25, 2007 | 3:51 PM
Warpig6's Avatar
ZX11OOF1,
Thanks! I knew that most were located on the drivers side (like the one I changed on my old Chevy S-10), but I couldn't find it even after the suggested posts...no wonder!
Semper Fi,
Warpig6
mltc78
Aug 22, 2018 7:53 PM
silverado 1500 2001
Sep 14, 2014 7:41 PM
DeHartShadow
Oct 22, 2013 10:52 AM
MrPuzzlez
Jan 4, 2009 12:02 AM
BigBlackS10
Oct 7, 2006 4:48 AM
