Fuel mileage dropped about 1.5-2mpg out of the blue
Old Jul 5, 2009 | 3:06 PM
stumpman's Avatar
Default Fuel mileage dropped about 1.5-2mpg out of the blue
Can any of you mechanincs tell me what would cause my mileage to drop all of a sudden out of the blue? I have an 04 2500HD 6.0 with 4:10 gears it's a 4x4 crew cab I normaly get around 9.9-10.2 pulling a trailer and got 9.2 pulling my camper last month and got 8.3 this weekend I got 14.2 on the highway last month with nothing behind it and got 9.9 this past week I checked it with pen and paper as well as what the computer said. It instantly dropped like over night I have 123,000 miles on the truck also have a K&N air filter in it that was just cleaned.
What can I do to bring it up I had a tuner on it but didn't notice much difference so got rid of it a while back.
Thanks for any help.
Old Jul 5, 2009 | 4:24 PM
racerx55's Avatar
driving into the wind towing a camper can make all the difference.
humidity, outside air temp, wind speed, all makes a difference. sometimes i get 15 towing my car trailer, other times i get 10 going the same road if its hot out.
Old Jul 5, 2009 | 4:42 PM
stumpman's Avatar
Yeah but this isn't the problem, I drive this truck every day pulling a tralier it has dropped like over night for some reason that I can't figure out. It has never got 15 mpg LOL I only wish.
Old Jul 5, 2009 | 8:21 PM
ukrkoz's Avatar
1. never judge based on single instance, any mpg calculations are subject to 10% varience, which is about right for you.
2. if it persists, look inot this:
- never fuel early in the morning, many stations have gas trucks coming in then, stirr crap from the bottom
- did you change gas station? stick to NEW and quality stations
- check your air filter
- read for codes
- O2 sensors? they'll do it
- run can of seafoam through tankful
- check drivebelt/-s
- running with a/c? windows down?
- check tire pressure
Old Jul 5, 2009 | 9:15 PM
stumpman's Avatar
- read for codes
Not a single instance it's been like this for about a week or more now. I'll try the seafoam but all the rest is the same nothing has been done different same gas stations same everything I pull the same trailer Daily with the exception of my camper, The filter was cleaned not long ago (K&N filter) The MPG changed a while after it was cleaned. I will have it checked for codes no lights have come on I thought if a sensor (02) was bad it would make the check engine light come on? always with the A/C on. Tire presures are good. Not sure what the seafoam will do to help bring back the MPG?????
Old Jul 6, 2009 | 5:53 AM
stumpman's Avatar
Anyone have an idea of what is going on with my truck, any mechanics ??
Old Jul 6, 2009 | 7:18 AM
bad2006z71's Avatar
check/replace fuel filter
clean MAF sensor
Old Jul 6, 2009 | 5:57 PM
stumpman's Avatar
clean MAF sensor
The fuel filter is in the tank how hard is it to replace?
Where would I find the MAF sensor?
Thanks!
Old Jul 6, 2009 | 8:11 PM
mudmaniac's Avatar
Ride of the Month
May 2009
Just a thought, but in many different regions of the US the fuel mixtures change based on the season. We recently started the summer season and I wonder if this may be a factor for you.
Old Jul 6, 2009 | 10:04 PM
stumpman's Avatar
No it pretty much is the same here it's been 90-100 degrees here for several months now. I am pouring a can of seafoam in tomorrow and see what happens I don't see it doing much but worth the try.
