Fuel Pressure regulator?
97 Chev K1500 w/5.7. Truck drives fine an normal pace, but if I floor it, it seems like it's not getting enough fuel. More of a hesitation/missing than a bogging feeling. When I check fuel pressure I get 60ish when I turn the key on, but it only stays there for a second and starts dropping till it hits about 10 PSI. If the truck is running the fuel pressure stays at 55ish and doesn't move if I rev the engine. I do have codes for the EGR pintle and the 2 downstream O2 sensors, but that wouldn't explain the fuel pressure problem. I'm taking a guess at the fuel pressure regulator, but don't want to rip anything apart if you guys have something else I should check first.
TIA!
Scooter
TIA!
Scooter
I was having a similar problem to the one you're having as well as the truck being hard to start when hot. The fuel pressure regulator did fix the hard-start problem but my problem is still there. When I floor it, it will go to about 4000 rpm then just stay there until I let off the gas. Not going faster or slower. Sometimes when it's really hot outside, it won't go about 3500 when flooring it. We might have kind of the same reason for our problems. I think it's a fuel pump issue.
Ok this may be a kinda dumb question, but I'm askin anyways! If the fuel pressure regulator went bad, Could it bleed the fuel back to the tank causing the pressure drop I'm getting with the key on and engine not running? It shoud hold pressure like that correct?
It would bleed the fuel into the intake plenum. The regulator is located below the plastic black upper intake. There is an injector unit that looks like a spider. The regulator is on the spider. So you would have to take the black upper intake off in order to access the regulator but it would just bleed off into the intake. Usually when you take the black upper intake off, you will see a clean spot right below the regulator. That is where the fuel is leaking.
The Truck has almost 300,000 miles on it. It got a new motor last spring. I've had that plenum off multiple times. I can do it with my eyes closed now!!!
solerano
September 1st, 2013 5:26 PM
carlsndfw
January 8th, 2007 5:10 PM
