fuel problem
Old Mar 30, 2015 | 2:53 PM
silverado00's Avatar
Default fuel problem
hey bowtie guys having some troubble with my 2000 silverado v6 its cutting in and out when i drive fule wise and i replced the fuel filter and fuel pump, and its still cutting in and out and i have a check engine light on that says its the fuel pump so any suggestons would be awsome thanks again
Old Mar 31, 2015 | 11:18 AM
Possibly fuel pressure regulator is bad. How long ago was fuel pump changed and did you use a Delco or Delphi pump? The others are cheap and usually do not last long.
Old Apr 1, 2015 | 6:28 PM
iriegnome's Avatar
I had a similar problem. Turned out to be a bad alternator belt. My car acted exactly how you are describing yours is acting. Sputtering, not taking off like no gas was getting to the carb, it would die at intersections. You name it. Did a tune up, fuel filter, went through the carb, nothing changed. Then the belt broke on my kid as she was heading to the store. Changed the belt and no more issues at all. None..
Old Apr 1, 2015 | 8:02 PM
what is the code. I never heard of a code for a fuel pump.
hunter10220
May 18, 2011 8:37 PM
scottkern3
Dec 7, 2009 7:53 PM
harascho
May 11, 2009 2:10 AM
MrPuzzlez
Jan 4, 2009 12:02 AM
