Fuel pump bad - 2003 5.3L
Hi;
Truck is hard to start at first, starts quickly at 2nd attempt. Fuel pressure gauge shows ~20 psi when the key is first turned on; get 50 psi after turning key off and then on again. However, pressure drops quickly to ~10 psi as soon as you hear the pump turn off. So, we'll replace the fuel pump assembly (the gauge is erratic, not accurate at upper 1/2 of tank volume).
Any recommendations on pump assembly mfr - Carter? Delphi? Anyone know what GM uses - I've heard it was Delphi.
Thanks.
Thanks.
mangomanj
Aug 17, 2014 9:51 PM
BRB
Dec 28, 2012 8:34 PM
hunter10220
May 18, 2011 8:37 PM
