Gas gauge vibrates
Old Apr 30, 2006 | 10:09 PM
73resto's Avatar
Default Gas gauge vibrates
Any one have a gas gauge that vibrates and bounces when the key is turned on and off?
Is it an expensive dah board replacement?
Can i take parts off of a 88 silverado to fix this problem
I have a 1998 silverado 1500
Old Apr 30, 2006 | 11:50 PM
Nomad76lj's Avatar
Default RE: Gas gauge vibrates
how much does it move when you do that is it extreme or more like gas sloshing around in the tank?
Old May 25, 2006 | 12:50 PM
MGLight13's Avatar
I dont know if we are having the same problem but when ever i fill up my 99 silverado the gas guage goes back in for from empty to full for the first 30 or so miles. Does anyone have any ideas whats wrong
Old Apr 14, 2008 | 9:41 PM
rockmaples's Avatar
Hello,
My guage flickers all of the time. It started last year but it still works.
P
Old Apr 25, 2008 | 3:38 AM
hquick's Avatar
I can tell you exactly what it is.
This is an EXTREMELY common issue with the OBS (88-98) trucks and SUV's.
There are 2 issues which cause this.
1 - if the needle moves around like the fuel is sloshing...it's most likely the sender fingers have worn away...which requires a tank drop andpump removal so as to replace the sender.
Damaged contacts (the little fingers)
OK..sender (see each tab has three little fingers)
2 - The little pulse motor at the back of the guage is shot...which usually causes the needle to fluctuate/vibrate like a hummingbird.
These cost about $10 I believe and an be replaced but necessitate removal of the dash.
ahearnm
Mar 19, 2023 6:37 PM
esnyders
May 9, 2013 11:05 AM
schmity
May 22, 2010 1:57 PM
dacrew4009
Oct 1, 2009 7:35 AM
walter
Astro
Sep 30, 2007 10:00 PM
