Gas/m problem
Old Jun 7, 2012 | 9:52 AM
vrmvrm's Avatar
Default Gas/m problem
Hi. I just serviced my truck and put SPECTRA air filter and E3 spark plugs. I thought that will give me couple of more miles per gallon, but it didn't. My truck does 15m per gallon!!!!!????? I don't burn rubber or make doughnuts. No racing. I don't excelerate like its burning under my feet. Its a 6 cylinder, 2001, 1500. For 90% of time truck is empty (no load in the back). What should i do?
Thanks for reading.
Old Jun 7, 2012 | 9:57 AM
vrmvrm's Avatar
And if some one can explain to me how to turn of "SERVICE ENGINE SOON" light. I have truck book and a manual but i can't find how to shut it of.
Thanks
Old Jun 7, 2012 | 10:08 AM
Doug Roberts's Avatar
So you want better MPG well brother buy a car ahaha no joking there's not much u can do cold air intake different tires take spare tire off fill tires but that's about it
That light go to advance auto they will can something wrong if you can't fix it you can pull light
Old Jun 7, 2012 | 10:30 AM
agentruley's Avatar
Replace the 02 sensor that is in the exhaust. It is very common for these to go bad and clean your MAF or MAPS. What happens is that if one of these is bad/dirty, it cannot report the right information to the ECU and then in return the ECU runs your engine REALLY rich and then you get terrible gas millage.
Old Jun 7, 2012 | 10:44 AM
vrmvrm's Avatar
I did clean MAF abo 6 months ago, but i heavent thought abo O2 sensor. GOOD CALL! I see in magazines chips that spous to give you better milage per gallon. Is that something for real or just another bling for the truck?
http://www.gfchips.com/chevroletsilveradoc1500.aspx
Old Jun 7, 2012 | 11:42 AM
If you get a code, you should read it as it might lead you to a problem area. Autozone or Advance can read it for free and also reset it. But if problem is not corrected, the light will come back.
Old Jun 7, 2012 | 12:41 PM
agentruley's Avatar
CHEVROLET SILVERADO C1500 GF Peformance Chip
Unless you know someone who owns one, i think its not worth the money. With simple things like building your own exhaust, checking sensors and whatknot, you can increase mileage 1-4mpg from stock, but first you have to get to stock. Make sure your tranny isnt slipping when it is in overdrive. And see if that sensor needs to be replaced. Sometimes, some cars have more than one. I know a dinky camry has like 3.
Old Jun 7, 2012 | 3:17 PM
birdie's Avatar
Default normal
i have a 2009 v6, 4.3 and 15 mpg is what it gets. not much you can do.
Old Jun 7, 2012 | 7:26 PM
My 99 V6 4.3 gets more like 17 mpg with 166,000 miles on it.
Old Jun 8, 2012 | 5:44 AM
agentruley's Avatar
i have a 95 4.3 Vortec v6 and i get right at 25. What the heck guys. Why so bad? I mean, mines a 5spd if that makes any difference. 3:23 gearing. Too bad im sawpping it out for a flat-tappet carb'd 350. Then I will say hello to 18 mpg. Atleast its supercharged.
