Gas pedal not functioning when brake relay is removed
Hey there everybody… new to this forum and in search for some help… I have a 2001 c3500hd that I’ve been having some issues with.. and could surely use some help/guidance…
Been struggling with a reduced power issue…but in the process, noticed that when I had the accelerator pedal pressed and pushed the brake pedal, the gas pedal was not working….
any one know if this is normal or maybe I have a fault?
any help would be appreciated..🙏🏽
does it have drive by wire throttle or a cable operated throttle? post the engine size.
reduced power messages will set codes. post the codes here when you get them read with a scan tool and i can help with diagnosis.
Truck still has these codes but now revs a little over 2k …..
but one thing I find interesting is that while I was pressing the gas pedal I pressed on the brake pedal and it disabled the accelerator pedal..
Having said that, I was curious and disconnected the brake relay… and that disabled the gas pedal!
is this normal?
is this normal?
Thank you for your help and patience…
Got really busy with the kiddos. Anyhow… so I just checked voltage..
so for tps 1 : Tps 2 : wouldn’t move
passed 4.85v.
WOT = .35v. This reading was at
Idle, closed and wot!
IDLE = 4.01- 4.02
CLOSED = 4.55
passed 4.85v.
IDLE = 4.01- 4.02
CLOSED = 4.55
