Gas tank hose
Old Jul 10, 2021 | 12:20 PM
mcivatte's Avatar
Default Gas tank hose
I have been having problems starting my 99' Chevy Silverado 1500 with the 5.3. when I do get the truck started by pressing all the way down on the pedal nothing happens. I found a hose/tube disconnected on the top rear of the gas tank. Could this guy be the solution to my problem, I can turn the key over and hear the fuel pump come on. I replaced the fuel filter. I am getting a P0443 code which has something to do with the EVAP. Any ideas...
Old Jul 10, 2021 | 9:05 PM
oilcanhenry's Avatar
P0443:
Bad purge solenoid (internal short or open)
Wiring harness chafing or rubbing another component causing short or open on control circuit
Connector worn, broken or shorted due to water intrusion
Driver circuit inside powertrain control module (PCM) is bad
You need to clean that plug up good and try to reinstall it on your fuel tank. That is why you are getting the OBD II P0443 code. It sends gas fumes to the evap canister where its collected and burned in your Chevy 5.3 V8 motor. Hopefully that will do the trick for you
wilbert melrose
Spark
Mar 28, 2021 7:28 AM
MEB
Oct 7, 2020 12:52 PM
Kstay
Jan 4, 2020 9:55 PM
JacktownYooper
K5 Blazer
Jan 10, 2015 9:04 AM
freddyp
Oct 20, 2009 7:21 AM
