good mod for 305 tbi pickup truck
so i did the quarter mod, which you put a quarter in your fuel pressure regulator, and it is amazing. actually found something that woke up my old 305 tbi. 0-60 times were cut down a 1/3 of the time and has amazing throttle response. what other really cheap mods out there that i can do to my truck?
mods:
quarter mod, K&N filter with custom ram intake, cat-back straight pipe, MSD coil, and 350 injectors
mods:
until today when it blew the injector pod gasket out. took quarter out and it was really bent up. gonnna make an adjustable fuel pressure regulator and hook up a pressure gauge so i can keep taps on it
They make aftermarket adjustable ones, on the marine TBI's they run the fuel pressure at 30 psi +-2,i think thats the pressure the big blocks run with TBI setup i think the stock small block pressure 9-12psi
stock fuel pressure on my tbi is 14 psi. i think if i had gotten a better seal on my gasket it would have held better but i'm just going to wait until i get more money to do other things to the motor
smallblocks
March 14th, 2008 12:10 AM
smallblocks
March 13th, 2008 10:11 AM
