got a question
![Question](https://chevroletforum.com/forum/images/icons/icon5.gif)
on my 90 chevy c1500, everytime i take off it seems to have a hesitation then it kicks in. it seems to be alot worse when its cold to and i always have to press the gas in the mornin for it to stay running when its cold. how could i fix the hesitation?
Also get some carb/throttle body cleaner and spray the intake out/clean the vac lines ect..
there is also a product called Seafoam it can be purchased pretty much anywhere, do a good flush with that and your BOUND to be running smoother!
"Old Wrench" has a good one too, my egr and iac were bad and cleaned up performance greatly.
also if you had your distributer adj for any reason during the plug/wire/cap get the timing adj.
but ONLY if you moved it!
good luck
good luck
antmesa
August 28th, 2006 3:35 PM
