got a question
Old Sep 4, 2011 | 7:41 PM
aubrycox's Avatar
Question got a question
on my 90 chevy c1500, everytime i take off it seems to have a hesitation then it kicks in. it seems to be alot worse when its cold to and i always have to press the gas in the mornin for it to stay running when its cold. how could i fix the hesitation?
Old Sep 4, 2011 | 7:55 PM
aubrycox's Avatar
please, somebody help me!
Old Sep 5, 2011 | 6:57 AM
makingaZJ's Avatar
new plugs, wires, distributer cap, and rotor button would be a good start.
a total D-I-Y tune up on the truck would prob cost $100 or even less.
good luck bud!
Old Sep 5, 2011 | 7:01 AM
makingaZJ's Avatar
Also get some carb/throttle body cleaner and spray the intake out/clean the vac lines ect..
there is also a product called Seafoam it can be purchased pretty much anywhere, do a good flush with that and your BOUND to be running smoother!
Old Sep 5, 2011 | 7:39 AM
OLD WRENCH's Avatar
Check for vac. leaks and see if your EGR valve is working.
Old Sep 5, 2011 | 11:20 AM
aubrycox's Avatar
i already got spark pllugs and wires . so ill try cleaning the throttle body and doing seafome
Old Sep 5, 2011 | 7:28 PM
makingaZJ's Avatar
"Old Wrench" has a good one too, my egr and iac were bad and cleaned up performance greatly.
also if you had your distributer adj for any reason during the plug/wire/cap get the timing adj.
but ONLY if you moved it!
good luck
Old Sep 6, 2011 | 6:27 AM
shamrock246's Avatar
coolent temp sensor?,fuel pressure?
Sean
97 4x4 burb
robertehess
Apr 21, 2011 2:01 PM
Terry Neff
Site Feedback
11
Apr 23, 2010 3:24 PM
Shnail
Sonic (Aveo)
Feb 3, 2007 6:58 PM
antmesa
Aug 28, 2006 3:35 PM
