Hard shift
2000 Silverado with 4.3 engine....112,000 miles
Under moderate acceleration the 1-2 shift is quite hard. All other shifts seem normal. Normal acceleration the 1-2 shift seems normal.
Any ideas.
Any ideas.
Change the fluid and filter, and add a container of "Lube Guard" While I am not a great snake oil fan this stuff works. A lot of the trans shops in the area put it in on every rebuild. It wont repair broken or worn parts but if they are varnished up it will help.
i have the same issue and have tried to diagnose it for years, i bought a new jasper transmission after mine finally broke and checked the conition of the rear differential, and even the transfer case. but even after the new jasper i still had the issue. i finally figured out that the driveshaft was the issue. the connection was loose on the rear diff. U-joint could also be the issue, though it is not with mine
mowglie
Sep 23, 2014 4:20 AM
