hard wire rador detector 09 chevy
If you're going to hook it up to accessory power then you need to use a relay as there are no accessory wires in the vehicle strong enough to add additional accessories to them. Go to the ignition switch and use the brown wire to trigger a relay and get the battery voltage for the relay at the back of the instrument panel fuse box
Go to the lower left IP (box by your left foot under the drivers dash). Look the the two rows of connectors. Left row second from bottom. Use pin 1 for ground and pin 7 (top left pin) for a 20 amp switched 12 volts.
