Headlamp replacement
Old Jun 18, 2007 | 8:30 PM
brims's Avatar
Default Headlamp replacement
I took out the low beam bulb on the driver's side of my 07 Silverado NBS just so I knew how to do it when the time came to change them. Well the bulbs are burried behind the washer fluid reservoir and brackets and whatnot. I wasn't able to turn the low beam bulb (top bulb) completely vertical which is the fully engaged position. I took the 2 top bolts off of the head lamp assembly to get more room but I couldn't get the bulb to spin completely pointing down. I know there's probably a simple solution I'm overlooking but any help would be appreciated. Thank you in advance.
Old Jun 21, 2007 | 9:54 PM
brims's Avatar
Default RE: Headlamp replacement
bump
Old Jul 6, 2007 | 7:10 AM
cheyenne06's Avatar
I know the headlamps are different on the NBS, but did GM keep the great idea of being able to pull a pin and remove the headlamp assembly, like on the 2003-2007 classic?? I have an '06 and it's a joke to change. I just take off the entire assembly. [:-]
Old Aug 12, 2007 | 1:48 AM
brims's Avatar
I don't think there's a pin to remove the assembly but I'll look for it. I tried removing it but there were some bolts I couldn't easily find though I should know where they are so when I need to remove the assembly to replace the bulbs I won't be stressed out.
Old Aug 12, 2007 | 1:47 PM
kcb37's Avatar
little hands.
MPM1972
Mar 22, 2011 9:14 AM
weewun
Apr 13, 2009 9:37 AM
ketchem
Jan 25, 2008 11:49 PM
Garbage943
13
Jan 21, 2007 2:23 AM
