Heated seat problem
I have an 07, Silverado w/ heated seats. The back heater works but the bottom seat heater does not heat.
Are there separate fuses or circuit breakers for the back and bottom heating elements?
find diagram in a manual in local library, any chilton should have it. probably, bad heating element, sorry. expensive.
you know, why not peak under the seat - maybe u r lucky and it's just loose contact?
My 06 tahoe has the same similar issue. Both back and bottom seat heaters turn on automatically; summer, winter, whenever.
I'm told(by my ex-chevy dealer mechanic) the issue isn't in the switch on the door, there's a 'control box' in the door itself. And that it's common. He just replaced on a chevy pickup.
I'm going to the junkyard for the cheaper part and will try that.
Hope this helps and good luck.
