HEATER SWITCH
Old Nov 21, 2006 | 1:07 AM
dfpotter's Avatar
Default HEATER SWITCH
I have a 2004 Duramax with a heater switch problem. I hope someone has solved this problem before and can help me. The problem is the switch only turn on the blower at top speed #5 on switch. Anything else delivers no air, but when it does come on at 5 you do get the maximum delivery
Thanks for looking...........................Dan
Old Nov 21, 2006 | 12:26 PM
golfer's Avatar
Default RE: HEATER SWITCH
One of two things:
#1 - the switch itself
#2 - the voltage divider circuit ( resistors ) I'm not sure if your 04 still uses the resistors or a more complex cicuit.
Hope this helps.
Old Nov 23, 2006 | 1:12 PM
63rodder's Avatar
I had the same problem with my 1500. The fan speed selector would not work on the number #1 speed. Speeds 2 thru 5 worked fine. I took it to a local shop and they replaced a resistor. They charged $120.00. That's been about 2 months ago. It's still working.
Hope this helps,
loced27
Apr 17, 2013 1:50 AM
05colorado
Dec 5, 2008 2:50 PM
tcmckay
Uplander
Sep 26, 2008 12:07 PM
mace
Mar 12, 2008 6:40 PM
bowtiez
Dec 17, 2006 10:24 PM
