Hello everyone and I could use a little help with 1995 z1500
Old Nov 3, 2014 | 12:23 PM
Ikkarus1's Avatar
Default Hello everyone and I could use a little help with 1995 z1500
Hey everyone,
I have a 1995 chevy z1500, and I have two issues I think are part of the same thing.
1. My truck seems to run cold by cold I mean somewhere around 150, or near the first 1/4 of the temp gage.
2. My heater is not blowing hot air. (steps taken for the heater, the AC does work, controller does make the air come out of different vents, heat blend door actuator does seem to move when I turn it to hot so I assume the problem is not with something inside the truck cab)
My truck doesn't overheat so I didn't think it was the thermostat, but I started the truck took the radiator cap off and let it run for about 10 minutes and it never overflowed.
The top radiator hose felt warm but not hot.
The heater hoses or the one I could reach at the time felt warm but not hot.
Maybe my temperature gage is not working correctly and the thermostat or water pump is failing and I can't tell but then wouldn't I have steam coming out of the radiator?
I am not sure where to go from here.
Any help would be appreciated.
John in SC.
Old Nov 3, 2014 | 11:27 PM
Rednucleus's Avatar
Replace your thermostat, probably stuck open.
Old Nov 4, 2014 | 2:38 PM
canakin's Avatar
Yea, it may be stuck open as indicated. I believe the recommended operating temp is 195, but you can get 160 and 180 thermostats. Have you always owned or is this new to you? Someone else may have put in a different thermostat??
NT_Hardcore
Astro
Jun 23, 2011 11:39 AM
Erik the Red
Oct 18, 2010 8:30 PM
jla74
Oct 13, 2009 6:48 AM
Scootertrash
14
Jul 26, 2009 10:32 PM
blabontefan
Aug 14, 2007 9:34 AM
