help!
Old Feb 5, 2008 | 7:57 PM
crookedpanels's Avatar
Default help!
Alright guys/girls here is the story. I have a 1997 2500 with a 5.7 vortec for a plow truck. Drove it to the store shut it down, came out and no start, hard crank, kick back, and starter grinding occured. I replaced the starter and cleaned the crank posistion sensor. It started and ran fine, then i parked cause i didnt need it. I started it one other time and it started fine.
went to start it the other day and the same symptoms as before occured. I replaced the crank posistion sensor this time with no difference. Now i am at a loss, any ideas? Thanks in advance.
T
Old Nov 26, 2008 | 1:33 PM
woody_texas's Avatar
Default RE: help!
check timing make certain destributor is tight
Old Nov 27, 2008 | 3:35 PM
therewolf's Avatar
Default RE: help!
Assuming your system has a distributor, also make sure the rotor is in good shape and tightly attached.
luni1974
Apr 29, 2014 2:31 PM
josh46970
Jul 28, 2011 12:19 AM
vwwebb
Jan 23, 2011 5:03 PM
kenney
Jan 31, 2009 5:29 PM
jharper
Dec 11, 2007 4:15 PM
