HELP!!!
Old Apr 9, 2007 | 3:56 PM
abew330's Avatar
Default HELP!!!
ok people, i need help!!
i need to fix my truck today
this morning my truck just died.. i was driving along and then i press the gas more down and my truck just dies..
once i'm off to the side of the road i try to re-start the truck and it just turns over.. (cranking) acting like it wants to start up but something is stopping it from starting
i know its not the battery, the alt, starter... but what could stop it from starting???????
does the fuel pumps go out often on these trucks??
maybe a sensor keeping it from starting?
you guys got any ideas that i should be looking at?????
any help please!!!
Old Apr 9, 2007 | 5:00 PM
RonH's Avatar
Default RE: HELP!!!
You need to check to see if you have fire and if you have fuel. Tracking the problem starts with that.
Old Apr 9, 2007 | 5:22 PM
abew330's Avatar
Default RE: HELP!!!
so poor a little gas in the TB then.. but what else besides that would cause the truck not to start???
ima check that in a bit
Old Apr 9, 2007 | 10:57 PM
golfer's Avatar
Default RE: HELP!!!
Well ... your truck needs 3 things to start and run :
air
fuel
spark
... start with those.
Old Apr 10, 2007 | 12:25 AM
engine2's Avatar
Default RE: HELP!!!
sounds like classic bad fuel pump
Old Apr 11, 2007 | 5:30 AM
abew330's Avatar
Default RE: HELP!!!
how do i test the air and spark?!?!?!?
its got gas!!! i put in the new pump but still no go!!!!!!!!!!!!
you guys got any ideas i would think its the coil but i dont know
what could i check or test to fix my truck!!?????
Old Apr 11, 2007 | 2:04 PM
sm3earl's Avatar
Default RE: HELP!!!
To check spark, get a spark checker, there around $7 at napa or a store like that.
Old Apr 11, 2007 | 7:20 PM
abew330's Avatar
Default RE: HELP!!!
its gotta have spark it almost started 3 times...
the pump is new
the pump isnt staying on... on the other silverado the pump stays on for about 3 seconds! mine only 1 second.. i turn the key and it throws fuel but shuts off after that second
Old Apr 11, 2007 | 8:58 PM
sm3earl's Avatar
Default RE: HELP!!!
when you crank, it should hold pressure in the rail, get a fuel pressure gauge.
Old Apr 11, 2007 | 10:50 PM
ZX1100F1's Avatar
Default RE: HELP!!!
ORIGINAL: sm3earl
My spark checker is 13 years old, the conversation goes something like this: "Come over here boy, lick your hand and hold onto this thing for a minute".
It upsets my wife but saved me a trip to the store and 7 bucks.
