Help with 98 c1500 4.3l !
Old Feb 5, 2008 | 6:09 PM
jss5891's Avatar
Default Help with 98 c1500 4.3l !
Hello guys i have a 98 c1500 4.3l with a 4l60e automatic transmission.The issue is when i turn the key the radio and dash lights come on and the gauge lights but the gauges themselves do not come on or the fuel pump.Then sometimes when i turn the key they both come and the truck will run fine So i assume it is a electrical problem i could be wrong.So far i have replaced the fuel pump the fuel pump relay fuel filter and a new ignition coil. Any advice or suggestions are appreciated. Thanks jss5891
Old Feb 5, 2008 | 6:54 PM
RonH's Avatar
Default RE: Help with 98 c1500 4.3l !
I would look at the ignition switch.
Old Feb 6, 2008 | 9:13 PM
shawnvw's Avatar
Banned
definagely soiunds like an ign switch......probe the wires when the problem is happeningto make sure you have power on al neccessary wires
Old Feb 7, 2008 | 11:25 AM
jss5891's Avatar
Yeah guy i think i found the problem i was messing with it and hit the key inward and then everything came on i tried it over and over and it all came on if i hit the key in. I think it is the tumbler that needs to be replaced i am trying to replace that later today maybe it wont end up being the ignition switch itself.
Thanks jss5891
FLAVADAVESCBR
Dec 27, 2022 6:05 AM
lildude_3675
Dec 10, 2008 5:09 PM
nabiljury
Aug 30, 2007 2:01 PM
alex07
Mar 28, 2006 10:59 PM
dwmmatt23
Mar 18, 2006 5:34 PM
