help lifting my truck
Old Mar 15, 2010 | 5:10 PM
isrummell's Avatar
Default help lifting my truck
does anybody know how i can lift my truck cheaply. i want around 2 inches, i just need to know how to lift the front.
Old Mar 15, 2010 | 5:13 PM
nauticstar87's Avatar
Is your truck 2wd or 4wd?
Old Mar 15, 2010 | 5:15 PM
therewolf's Avatar
Thread search "torsion bar adjustment" in this section.
If you do make any suspension adjustments, be absolutely certain you have the truck aligned immediately. Your tires could prematurely wear very quickly.
Old Mar 15, 2010 | 5:26 PM
isrummell's Avatar
4 wheel drive
Old Mar 15, 2010 | 5:29 PM
maxxman04's Avatar
http://www.readylift.com/c-46-ck-150...-6-lug-15.aspx
or you can crank with the stock bar keys in, but you may end up with a little stiffer ride.
Old Mar 15, 2010 | 5:31 PM
therewolf's Avatar
This would give it a "K" 1500 designation. The "C" designation is for 2wd GM trucks.
Old Mar 15, 2010 | 5:34 PM
Just crank the t-bars if you want cheap, and it'll be a rougher ride. Be sure to measure the fender height before and after to be sure both sides are even.
GET A ALIGNMENT afterwards.
Old Mar 15, 2010 | 5:41 PM
isrummell's Avatar
im think about getting new keys but i dont wanna screw up my 4 wheel drive. thats the piont of me lifting it
Old Mar 15, 2010 | 6:00 PM
maxxman04's Avatar
the new key do not mess up the 4wd at all. it simply lifts the front end while maintaining a stock ride.
Old Mar 15, 2010 | 6:02 PM
isrummell's Avatar
but it changes the angle of the cv joint right?
