HELP! Transmission filter replacement problem. NEED HELP!
Old Feb 24, 2007 | 2:53 AM
dh0765's Avatar
Default HELP! Transmission filter replacement problem. NEED HELP!
I have a 2003 Silverado Ext Cab Z71. I am in the process of trying to change my transmission fluid and filter. I drained the fluid from the pan. I removed the heat shield from the passenger side as instructed by the manual. The manual instructed to remove the shift cable bracket from the driver side of the transmission. I can't get it off, and it is in the way of getting the pan off. There are two bolts that I can feel on top, but they are very hard to access, and I can't even tell what kind of bolts they are. I think they may be allen wrench heads, but they are not very accessable, and I can't seem to get them loose with an allen wrench. Without removing this bracket, I can't get the pan off. Please help!
silverado 1500 2001
Sep 14, 2014 7:41 PM
DeHartShadow
Oct 22, 2013 10:52 AM
gilbertnewcomb
Oct 31, 2006 2:19 AM
BigBlackS10
Oct 7, 2006 4:48 AM
clint59
Cobalt
Aug 24, 2006 5:14 PM
