High beam indicator
Old Sep 1, 2024 | 9:05 PM
  #11
Gypsyspring's Avatar
You are amazing! Thanks ever so much. I need my truck..........i'm on the ren faire circuit for a living, and still have work to do before i can stay home
Old Sep 22, 2024 | 8:47 PM
  #12
iHackDifferent's Avatar
Default Having the same issue!!
Hello Group! I am having the same issue, however mine was killing my battery, after I turn off the truck with keys out and door shut. 10 seconds later the Hi Beam indicator light in the cluster will come on and act as if it going in and out, also the time on my stock radio would keep cutting on then turning off. So if my truck would sit for a couple days the batteries would be dead. So I took the radio out and it seemed to stop draining my batteries. Could this be a Security thing? Or the BCM? Thanks in advance! It is a 2005 Silverado 2500hd 108k
Old Sep 23, 2024 | 2:38 PM
  #13
Replacing the dash cluster fixed that issue for me. And weirdly enough, it also fixed my dead right speaker! Who'da thunk it? Now, we just need to put in a kill switch for the new brake controller......it has a constant 50 milliamp draw, that the company says is normal! snort!
Old Dec 19, 2024 | 8:42 AM
  #14
TMG007's Avatar
Default Tried to message you
Originally Posted by Gumby22
The GM diagram(s) are attached.
The cluster only controls the on/off function of the high beam indicator. It receives the command to turn the indicator on/off from the BCM which monitors the multifunction switch for driver request.
If the power & ground feeds to the cluster are good, try pulling the fuses for the headlight circuits one at a time and recheck for the indicator after each one. There’s 2 fuses per each side - 1 for brights, 1 for dims - there’s also 1 fuse for the DRL circuit and 1 for the fog lamps.
If it doesn’t go out after the headlight fuses are pulled, try also pulling the fuses labeled “TBC” & “TBC IGN 1” as these are battery feeds to the BCM. Note that your truck may not be equipped with both TBC fuses depending on vehicle options.
If the indicator goes out after removing a specific fuse, suspect a short circuit and/or faulty BCM.
I can provide further diagnostic steps if needed.
2006 Silverado 1500 5.3
I tried sending you a message. The system won’t let me. I have some questions regarding this issue. I just got done putting a 2000 LQ4 6.0/4L80E in my 2006 single cab 4.3/NV3500. I’m using the harness for that motor. I just repinned it to match the C2 connector on the fuse box. I got it running, all gauges work except oil pressure (I’ll revisit that at a later time. I have a manual gauge for now.) My bright lights indicator is one after I turn key off and pull it out. If I pull the lever to turn them off, indicator goes off, but then comes back on after a few seconds.
Old Dec 19, 2024 | 12:05 PM
  #15
Gumby22's Avatar
Did you also replace the fuse block as well? Because The drivetrain swap shouldn’t have affected the lights - the lights are pinned at C4 of the under hood fuse block.
The diagrams already pictured should be the same for your truck in terms of lighting control, so the cluster is relying on a signal from the BCM to turn the indicator on & off.
Based on your description of the issue, I suspect the dimmer switch is shorted. The easiest test would be to unplug the switch and see if the indicator stays off. If yes, replace the switch - if not, the next step is to unplug C3/C4 at the BCM and recheck. If it’s out, the BCM will need to be further tested - if not, the cluster is likely malfunctioning but the power & ground circuits need to be checked before it can be definitively blamed.
Old Dec 19, 2024 | 12:46 PM
  #16
TMG007's Avatar
Default Got It
Appreciate the response! I fixed it without trying. I didn’t have my HP Tuner interface at my buddies house after pinning my efans. So to get me home with fans I jumped on relay to the other(the one I’m assuming that goes through the lamp harness). This morning I plugged up and changed my A/C system settings from “recirc door” to “fan #2”. Took the jumper off to test fans and high beam issue was resolved
Thanks
Stoddards
Jun 17, 2019 2:02 AM
Andrei Sokolov
May 22, 2019 3:58 AM
manjunath
Sep 9, 2017 10:27 PM
mausc
Jun 27, 2017 1:18 PM
Whiskey_Sauer
Jan 12, 2017 7:34 AM
