High beams inop
Old Nov 17, 2012 | 11:12 AM
usmarine0905's Avatar
Default High beams inop
Hello everyone,
Have another a hope small issue with my 98 C2500 5.7 extended cab LB. 7-8 months ago I replaced the multifuction turn sig switch only because the cruise stopped engaging, that fix it. Ok now I have NO high beams, when I release my parking brake, my headlamp come on as designed. When I turn on Head lamp switch, my marker and tail lamps come on as designed. But when I try to turn on my high beam they do not come on. I hear the click in the switch but still no high beams, all other function assocated with the switch work fine. looking for area to try or replace? I was not sure if might be headlamp switch or multifunction switch or something else Im missing...
Thanks in advance
Old Nov 17, 2012 | 2:19 PM
so you have low beams and daytime running lights, correct?
Have you checked for power at the wiring harness at the high beams?
Old Nov 17, 2012 | 3:14 PM
daytime running lamps and low beams I have yes.... check power at harness, no. I should be checking at the switch correct?
Old Nov 17, 2012 | 5:48 PM
sure. you could check at the switch if its easy to access. should be powered at the yellow wire into the switch and light green wire out of the switch to the high beams.
if your not sure both highbeam bulbs are good; check at the bulbs?
Old Nov 18, 2012 | 4:08 PM
@ Tech2, thank you for the feedback... I went out today to check for power, as it always it I turned on the highbeams and they worked.. WTH... drove it and hit lots of bumps zig zags.. still working. removed the dash front and checked all connections and all are good and tight... oh well untill next time... Thanks for all your help
Old Nov 18, 2012 | 4:10 PM
kevinkpk's Avatar
Probably a loose connection, and you fixed it when you checked it.
Old Nov 25, 2012 | 2:02 PM
Ok, thanks for all the input... the problem was a bad headlight switch. I found it at night by accident. I was adjusting my dash lights using the wheel thingy..(lol) and eachtime I moved it, the highbeams with flash on / off. So a bad switch it is
Aaron Green
Cobalt
Mar 15, 2015 9:21 PM
regina92701
Dec 21, 2007 11:58 PM
PTT
Sep 20, 2007 6:11 AM
hunt_ak
Jul 28, 2007 9:38 PM
