High Idle CEL Flashing
Old May 20, 2012 | 5:01 PM
Hennessy's Avatar
Default High Idle CEL Flashing
Hi everyone Im James Im new to this Awesome fourm. I have a 1996 K1500 5.7L & its been a great truck its got 211,500kms, but lately It is idling very high it likes to accelerate up to 40km/hr without touching the pedal, the cel flashes only when i start it up and after 30secs of driving it goes out. Ive replaced the Tps, Iac, wires, Plugs, Cap & Rotor, Pcv, TB Gasket. Im taking it to a shop on wedesday but im hoping i figure it out. I just had a 360 spinal fusion or i would fix it myself any advise is greatful.
Thanks
James H.
Old May 20, 2012 | 6:59 PM
Look for vacuum leaks or disconnected vacuum line.
Old May 20, 2012 | 9:38 PM
cleveland63b's Avatar
i 2nd the vacuum leak but would also pull the code(s)
Old May 20, 2012 | 11:11 PM
Hennessy's Avatar
I also have alot of suction when I remove the Oil fill cap it almost dies I only get the po507 and i have cleared it bought a new Iac and it keeps coming back
Old May 21, 2012 | 5:10 AM
These are possible causes. From another site.
- Dirty throttle body
- Electric throttle control actuator misadjusted or damaged
- Faulty Electric throttle control actuator
- Intake air leak
- Poor electrical connection to the Intake Air Control (IAC) valve
Old May 21, 2012 | 9:29 AM
johntaps's Avatar
Former Sponsor
Post High Idle CEL Flashing
There are many reasons for po507 code coming again and again even after IAC has been changed. Have you checked the IAC motor connector? If it is ok then check for any open or ground IAC circuit.
Old May 21, 2012 | 10:00 AM
Hennessy's Avatar
Where is the Electric throttle control actuator located ?. Ive cleaned the TB right up & sprayed TB cleaner all over the engine with it running and got no change.
Thanks for the replies
Old May 23, 2012 | 11:14 AM
Hennessy's Avatar
Off to the shop hopefully they will figure it out!
in2pro
Dec 25, 2020 11:34 PM
endneu913
Aug 24, 2014 12:00 AM
otis_xing
Apr 13, 2013 2:31 PM
militarydave
Jan 29, 2012 5:44 AM
timdogg1313
Jul 18, 2011 6:43 AM
