hot air
I had that same problem with my oldsmobile Delta 88 and Buick Century.
Currently my silverados heater works great, but no such luck for the AC.
I believe the problem lies in either the temp control unit, or it is the compressor clutch.
I know about the air blowing out of the bottom when I turn the het on temp contol on red heat comes out even out of the vent when I turn the temp down to the blue cooler the air is hot. I turn the ac on still blows hot air but the comp comes on Thanks
Hi 98K,
Welcome to the Chevy Forums.
Sounds like you have a bad valve on your heater hose, which isn't shutting, or a malfunctioning climate control unit in your dash which isn't operating your heater control valve.
Look at the heater hoses under your hood first. There should be a 3/4 and a 5/8
heater hose going into your firewall. The larger of the two hoses(3/4) should have a control mechanism in the line. Is it properly connected?
Every thing under the hood looks okay the 2 hoses go to the motor no control yes it is funny situation I left it on the cool side all summer when temp started getting cooler I turned the heat on. The other day outside temp was warmer so turned the temp down on the inide of the truck and no cool air I was wondering if the temp control is bad or is there a way I can jump it out or do I have to replace the whole unit
It depends. If it's the inlet valve for the heater core, then it's most likely on the 3/4 heater line, under the hood, near to the firewall on the passenger side.
If it's the Climate Control Unit, that's on your dash.
TahoeMatt
October 15th, 2014 4:10 PM
Ronin7709
July 17th, 2013 12:36 PM
