hot air
Old Oct 15, 2010 | 9:59 PM
98k's Avatar
98k
Default hot air
I have a 98 k 1500 the temp coming out of the heater is always hot even when I turn the temp down to make cooler any sugg thanks charly
Old Oct 16, 2010 | 12:39 AM
Mille Racer 69's Avatar
I had that same problem with my oldsmobile Delta 88 and Buick Century.
Currently my silverados heater works great, but no such luck for the AC.
I believe the problem lies in either the temp control unit, or it is the compressor clutch.
Old Oct 16, 2010 | 6:37 AM
98k's Avatar
98k
I know about the air blowing out of the bottom when I turn the het on temp contol on red heat comes out even out of the vent when I turn the temp down to the blue cooler the air is hot. I turn the ac on still blows hot air but the comp comes on Thanks
Old Oct 16, 2010 | 9:54 AM
therewolf's Avatar
Hi 98K,
Welcome to the Chevy Forums.
Sounds like you have a bad valve on your heater hose, which isn't shutting, or a malfunctioning climate control unit in your dash which isn't operating your heater control valve.
Look at the heater hoses under your hood first. There should be a 3/4 and a 5/8
heater hose going into your firewall. The larger of the two hoses(3/4) should have a control mechanism in the line. Is it properly connected?
Old Oct 16, 2010 | 10:48 AM
98k's Avatar
98k
Every thing under the hood looks okay the 2 hoses go to the motor no control yes it is funny situation I left it on the cool side all summer when temp started getting cooler I turned the heat on. The other day outside temp was warmer so turned the temp down on the inide of the truck and no cool air I was wondering if the temp control is bad or is there a way I can jump it out or do I have to replace the whole unit
Old Oct 16, 2010 | 11:13 AM
2wd-K5's Avatar
i had a similar problem, so what i did was install a little ball valve in-line and i turn it off when it is hot out
Old Oct 17, 2010 | 6:56 AM
98k's Avatar
98k
where would the bad valve be not under the hood
Old Oct 18, 2010 | 8:07 AM
therewolf's Avatar
It depends. If it's the inlet valve for the heater core, then it's most likely on the 3/4 heater line, under the hood, near to the firewall on the passenger side.
If it's the Climate Control Unit, that's on your dash.
TahoeMatt
Oct 15, 2014 4:10 PM
philhill61
Apr 21, 2014 11:06 AM
EnyChevyUK
Aug 25, 2010 2:59 PM
