How to increase car torque?
Old Mar 18, 2013 | 12:08 PM
w002mia's Avatar
Default How to increase car torque?
Hello,
I would like to know safe ways to increase my trucks torque without harming the engine or anything else ?
I know modifications to engine must be made so the internal parts can handle heat and maybe pressure. Getting more air into the engine sounds like the engine pistons will suffer. but i guess it's the only way to increase torque since the engine is what moves the car lol
Old Mar 18, 2013 | 1:58 PM
country_09's Avatar
Do you want to do a build or just somethin like intake, headers, and a tune? Those will get you around 50-60 hp and tq numbers on a dyno.
Old Mar 18, 2013 | 2:33 PM
w002mia's Avatar
I would like to know the easy ways to add torque.. don't matter if i have to change internal parts but without hoisting up the engine. I want to do everything myself.. so dyno is a no no .. I'm just worried of what will happen to the engine of too much pressure from compression strokee. That's why i need to know what parts i'll need to change.
Old Mar 18, 2013 | 3:33 PM
kevinkpk's Avatar
Huh? What he is refering to is a dynometer test for torque, and horsepower. I think IMHO, you might just stick to adding headers.
Old Mar 18, 2013 | 3:37 PM
Mille Racer 69's Avatar
Here are a couple basic things.
1-install tires with a smaller sidewall. Like 265/25 rxx
The smalled tires will spin more easily.
You can install true dual exhaust for better low end torque.
You can install a cold air intake.
You can install a small Turbo charger for better power at mid and low range rpm's
Without going through head gaskets so quickly.
All these things, especially the last will definitely net you some torque
Old Mar 19, 2013 | 1:08 AM
w002mia's Avatar
Do i need to install sport cams and pistons or original parts will do just fine? what about spark plugs and distributor ? they add anything?
Old Mar 19, 2013 | 11:46 AM
country_09's Avatar
Keep oem plugs and wires. You can do a smaller cam. Somethin like a 212/218 112 lsa will be a more low end torquey cam.
For serious business though just do the Longtube headers, intake, single 3" exhaust, cam, converter and tune.
MathewsMan
60
Oct 20, 2014 11:39 AM
beigmatt
Aug 6, 2014 12:32 PM
JTraven572
Mar 2, 2007 2:09 AM
E A Wills
Jun 25, 2005 2:43 PM
