Humming noise 07 Chevy Silverado 4*4 1500 crew cab
Old Feb 8, 2020 | 1:51 AM
Kgarber's Avatar
Default Humming noise 07 Chevy Silverado 4*4 1500 crew cab
Have a humming noise coming from front passenger side when weight is off that side noise goes away replaced the hub assembly on that side twice first time the sound came up was a month after I changed it the first time changed it again still there it has gotten louder everything looks right feels tight out of ideas
Old Feb 9, 2020 | 1:59 PM
Irish_alley's Avatar
I'm here for the party
so after working on it replacing it the noise initially went away but came back? could be improper torque on the spindle nut causing the bearing to fail
Old Feb 10, 2020 | 3:25 AM
Kgarber's Avatar
I had no humming noise then my hub assembly went out replaced it no noises then a month later it popped up slight noise starting out got louder I used a torque wrench on it and it was to spec when I did it figured the hub that I replaced it with was bad even tho had no signs that it was bad replaced it the noise was still there
large a
Dec 27, 2019 1:22 PM
chvy24
Sep 27, 2015 3:04 PM
paalrobes
Jul 17, 2013 6:55 PM
SilveradoSteve
Jul 26, 2010 1:26 PM
Tatonka
Apr 8, 2008 11:07 AM
