HVAC Temperature Actuator Replacement
Old Oct 20, 2014 | 11:07 AM
gharph's Avatar
Question HVAC Temperature Actuator Replacement
I have an '08 Silverado crew cab with manual HVAC controls. I have visually verified that the temp actuator is faulty. (I can see the actuator on top of the HVAC unit between the radio and passenger center dash vent.) Is there a way to replace this actuator without removing the whole HVAC system.
Old Oct 22, 2014 | 10:19 AM
gharph's Avatar
Cool Update
Well after a few hours (and cold ones), I began to examine the passenger side dash. after removing the upper glove box I found four 10mm screws retaining the passenger airbag. after carefully unplugging the safety pin and plug the airbag was able to be removed easily. from there i was able to gain sufficient acces to the temp actuator to replace it. I have now determined that the Heater A/C control box is not fully working. I have ordered a new box in hopes that this will finally solve the issue.
Please note that EXTREME care was taken while disconnecting and re-connecting the airbag!!! Once I visually placed my hands on both sides of the plug I moved my head BELOW the dash to protect myself in case of deployment.
BigSarge54
Feb 18, 2023 8:38 AM
Barry A. Waters
Aug 17, 2019 11:12 AM
shawnvw
44
Dec 22, 2013 3:38 PM
ouldsmobile
Astro
Sep 30, 2009 7:48 AM
Spinner
Aug 10, 2009 5:23 PM
