I Am Lost Please Help
![Angry](https://chevroletforum.com/forum/images/icons/icon8.gif)
I Just Rebuilt My Chevy 350 I Replaced Flywheel and Go A Clutch Kit I Was Bleeding The Line And The Clutch Got Really Stiff At the bottom. i went to push it and blew out my hydrolic Line after replacing line i have the same prob again please help
You shouldn't bleed a clutch like a brake. With small pressure on the clutch pedal, open bleeder, then depress the pedal to the about the floor, close bleeder. Repeat till the pedal comes back.
Did you replace the slave cylinder? Sounds like the check is stuck. That would explain the pedal and busting hoses, the check in the slave is stuck, and won't relieve pressure off it.
Thank You for your help but i made a stupid mistake the slave cylinder wasn't hitting the fork and was hitting bell-housing which obviously wasn't gunna move but thanks for your post
Motivation21
September 26th, 2013 9:39 AM
tahoewife
October 11th, 2008 3:30 PM
