I Am Lost Please Help
Old Dec 30, 2012 | 6:22 PM
SImpleManFore's Avatar
Angry I Am Lost Please Help
I Just Rebuilt My Chevy 350 I Replaced Flywheel and Go A Clutch Kit I Was Bleeding The Line And The Clutch Got Really Stiff At the bottom. i went to push it and blew out my hydrolic Line after replacing line i have the same prob again please help
Old Dec 30, 2012 | 7:09 PM
kevinkpk's Avatar
You shouldn't bleed a clutch like a brake. With small pressure on the clutch pedal, open bleeder, then depress the pedal to the about the floor, close bleeder. Repeat till the pedal comes back.
Old Dec 30, 2012 | 7:13 PM
Right we did it like that Now the clutch is stiff and you cant push it down at all
Old Dec 30, 2012 | 7:19 PM
kevinkpk's Avatar
Did you replace the slave cylinder? Sounds like the check is stuck. That would explain the pedal and busting hoses, the check in the slave is stuck, and won't relieve pressure off it.
Old Jan 1, 2013 | 1:17 PM
Thank You for your help but i made a stupid mistake the slave cylinder wasn't hitting the fork and was hitting bell-housing which obviously wasn't gunna move but thanks for your post
spike1269
Jan 3, 2016 11:37 PM
Motivation21
Sep 26, 2013 9:39 AM
tahoewife
Oct 11, 2008 3:30 PM
prism
Sep 26, 2007 11:48 PM
