I HAVE ELECTRICAL PROBLEM
Old May 1, 2008 | 12:12 PM
alext's Avatar
Default I HAVE ELECTRICAL PROBLEM
i'M SEARCHING FOR THE ELECTRIC MANUAL OF SILVERADO 1500 OF 1992 5.7L V8 .PLEASE
Old May 1, 2008 | 2:41 PM
northey87's Avatar
Default RE: I HAVE ELECTRICAL PROBLEM
Welcome to the forum!!! Someone here should be able to help, just hang in there.
Old May 1, 2008 | 6:04 PM
alext's Avatar
thanks!!!
I hop some one can help me out.
Old May 1, 2008 | 8:01 PM
shawnvw's Avatar
Banned
What specifically are you looking for? I can get wiring diagrams of certain systems, but it doens't come in a general manual
Old May 2, 2008 | 2:45 PM
alext's Avatar
I have problem with IGNITION ,i don't have spike
Old May 4, 2008 | 3:08 PM
alext's Avatar
Iwant thewiring diagrams in order to see the wiring at the dristibiter.
Old May 4, 2008 | 11:06 PM
shawnvw's Avatar
Banned
Wiring from the distributor go directly to the PCM and to the coil and are as follows:
4 PIN Conn
A: Blk\RED TO PCM pin D13 -DIS REF LOW
B: tan\blk TO PCM pin D12 - HEI BYPASS
C: ppl\wht TO PCM pin D14- DIST REF HIGH
D: Wht TO PCM pin D11 - HEI SPARK TIMING
2 PIN Conn
Pink at ign module, to pink at coil. - IGNITION
White at Ign module to white at coil - TACH SIGNAL
There should be 2 pinks, and 2 white at the coil. They are crossed over inside the coil so they are the same circuit. One white wire goes to ign module, the other goes to your cluster. One of the pink wires goes to your ign module, and the other goes to ign switch
If you need more info let me know. Sorry i can't post the entire diagram, but The program i'm using won't let me cut\paste anything out of the program
Old May 5, 2008 | 6:35 PM
alext's Avatar
it"s not exactly what i am looking for but thank you very much enyway.
Old May 5, 2008 | 9:12 PM
silverado man's Avatar
Hi I go to my public library they have reference manuals and even some manuals you can check out
Old May 6, 2008 | 6:41 PM
rjsasaoka's Avatar
I have the same year that you do and have the CD-ROM version of Chilton's with an electrical schematics in a .pdf format I could send to you.
Top
Follow Us
