Notices
ignition problem
Old September 15th, 2010, 11:23 PM
meme6885's Avatar
Default ignition problem
so my ignition is stuck in the on position which is fine cause i wanted to hook up a push button start, just not sure how to, need some help to make it work, which wires where to where
83 c30 454
Old September 17th, 2010, 12:37 AM
gfd749's Avatar
sounds like u just need to change your ignition cylinder. i have had a truck 10 years ago that had a push button start on it. it was cool at first. then it just turned into more trouble then it was worth. a push button doesn't last as long as an ignition cylinder and the push button doesn't give you any warning before it goes out. regardless even with the push button. the key has to turn to the off position or u will run your battery down. sorry but i can't remember the wires. i wish i could be more help but i think u should weigh out the pros and cons before getting into that
dnncampbell
November 19th, 2013 5:54 PM
boho115
July 10th, 2013 7:15 PM
Truck Driver Bill
HHR
August 11th, 2011 8:48 PM
ftw52
April 19th, 2007 7:56 PM
Quick Reply: ignition problem
