Installed DIC Console no Temp or Compass
I just installed the DIC console in my recently purchased 2009 Silverado Crew Cab work truck and can't get the outside temp or compass to show up on the display. Everything else works but this. Does the work truck DIC not have a outside temp sensor and compass installed? Thanks for your advice in advance.
thunder001
thunder001
On my 07 Tahoe the temp sensors are located right inside the grill, I would suspect they are in the same or very similar place on the truck, if you see them then the option should be available if they are not there then you probably are not wired for the option.
theDIC switch should only give you the ability to see engine related items.. MPG,fuel gallons used, hours engine has ran and the tire pressure monitoring system reading of each tire, and average MPG if you have the active fuel managemetn system...
the compass and temp should all read thru the rear view mirror as mdtahoe stated...
senf
May 19, 2023 10:50 AM
MSDTRUCK
Feb 19, 2011 2:17 PM
