Interior Light Silverado
Old Aug 21, 2011 | 3:50 PM
baldana's Avatar
Default Interior Light Silverado
Hi,
I recently bought (imported) a 2008 Chevrolet Silverado LS and I have a very simple and naive question: Do the interior lights go "on" when you open the cab doors...? Obviously mine doesn't, reason for this posting.
Old Aug 21, 2011 | 6:58 PM
skeeter5's Avatar
Hi baldana,
Yes it should, you may have a blown fuse. Can you use your headlight switch or override switch near the headlight switch and turn it on manually?
This will let you see if the lamp is okay. Then it most likely is something to do
with the door switches.
Good luck.
Old Aug 22, 2011 | 9:40 PM
nechevy's Avatar
I remember having the same issue when I got my 2008 LT. There is a dome "override" button to the left of the steering column. That fixed mine. Check in your owners manual as well
Old Aug 28, 2011 | 10:53 AM
baldana's Avatar
OK, here are my findings:
The overhead light turns on both manually and through the "dome" switch. I cannot locate any door switch as like other cars, however I can read on the display info that my door is open. Still unable to have the light turn on when I open the door
Bassam
Old Jan 29, 2012 | 10:19 AM
baldana's Avatar
Solution here: https://chevroletforum.com/forum/sil...78/#post204678
paulg_ca
Oct 24, 2014 5:42 PM
nysmedic
May 13, 2013 10:04 PM
2004CMM
Jul 27, 2009 5:27 PM
Christina
Nov 8, 2006 1:12 AM
KBX500
Nov 4, 2006 9:53 PM
