Intermittent brake lights when tilting wheel
94 K1500 Blazer, I posted under fullsize trucks since it looked like there is more activity here than the Blazer section. My brake lights are intermittent when using the tilt wheel. I figured it was the wiring harness from the bottom of the column up to the signal switch so I got a new signal switch and fed the wires down thru the column and re inserted them into the connector and plugged the connector in to the wiring harness under the dash. Its still got an intermittent problem with the brake lights not working when tilted all the way down. The upper brake light works so I am sure it isn't the brake light switch and I also took it out and took it apart and cleaned the contacts and verified operation with an ohm meter. Kinda stumped unless I pinched a wire when installing the new switch but they all seemed to move freely in the column before I put it all back together. Is there something else I should be looking for?
Update: It is the other side of the connector down on the steering column, apparantly after all those years of tilting the column the wires push a little each time and it loosened the receptacle side of the connector.
warthogcrewchief
Sep 24, 2022 4:37 PM
its.all.hers.chevy
Oct 22, 2014 9:18 AM
skdevore
Aug 26, 2009 10:18 PM
