K1500 '93 Oil Filter Housing Leak
Got an oil filter housing leak,i replaced the rubber seal from the housing to the block and it still continues to leak almost a consistant drip. Any ideas? Need this fixed ASAP!
If you replaced gasket should stop. Did you clean all good? Maybe tighten bolts again.
Maybe it has a small crack in it. Maybe oil filter leaking.
Only other thing i can think of .. check valve sticking some getting to much pressure.
If they get stuck can blow filter off.
