K1500 '93 Oil Filter Housing Leak
Old Oct 11, 2011 | 10:41 AM
tduncan420's Avatar
Default K1500 '93 Oil Filter Housing Leak
Got an oil filter housing leak,i replaced the rubber seal from the housing to the block and it still continues to leak almost a consistant drip. Any ideas? Need this fixed ASAP!
Old Oct 11, 2011 | 6:13 PM
loosebearing's Avatar
If you replaced gasket should stop. Did you clean all good? Maybe tighten bolts again.
Maybe it has a small crack in it. Maybe oil filter leaking.
Only other thing i can think of .. check valve sticking some getting to much pressure.
If they get stuck can blow filter off.
Old Oct 11, 2011 | 7:15 PM
T.Neff's Avatar
Banned
You have a oil cooler??.
scott81425
Jul 9, 2014 8:36 AM
hucks 66
Jun 13, 2012 6:39 AM
Wick
Apr 24, 2010 4:46 PM
gonzoblazer
Feb 8, 2010 8:32 AM
trush
Jan 1, 2008 9:27 PM
