07 air filter housing
Old Jul 8, 2014 | 2:11 PM
scott81425's Avatar
Default 07 air filter housing
I apologize if this has been asked before. I searched and could not find an answer. I've actually searched all over the internet and can't find my answer. Anyway, I just got an 07 'burb Lt. For a pretty good deal (in my eyes) but it wasn't cared for the best before I owned it. So I'm in the process of doing all sorts of services and putting together what I can and etc to if. I was replacing the air filter earlier and I noticed its really loose. So I took it all the way apart to see of there was a clip missing or something. I can see a hole in the bottom of the housing where it looks like a bolt should go through to hold it down. But there's nothing in the plate below it to mount it to that I can see. It looks like the only thing that holds the mounting down are 2 little grommets. And there's supposed to be some wiggle to the housing. Is this correct? Can anyone tell me? Thanks.
Old Jul 8, 2014 | 10:38 PM
should be 2 plastic plugs that are part of the air cleaner box that push into the rubber grommets. the rubber grommets sit in 2 holes in the air box tray support. It will wiggle even when seated properly but should not shake or rattle.
Old Jul 9, 2014 | 8:36 AM
scott81425's Avatar
That's exactly how mine sits. Just saw a hole in the air box itself and thought maybe there was a clip or something designed to go in there. Guess not. Thanks for the reply!
silverado 1500 2001
Sep 14, 2014 7:41 PM
DeHartShadow
Oct 22, 2013 10:52 AM
hucks 66
Jun 13, 2012 6:39 AM
tduncan420
Oct 11, 2011 7:15 PM
gonzoblazer
Feb 8, 2010 8:32 AM
