leaf springs 98 silverado 2500
Old Apr 20, 2010 | 4:58 PM
usmarine0905's Avatar
Default leaf springs 98 silverado 2500
I have my 98 silverado 2500 extended cab long bed. is there anyway to soften the ride in the rear? I know it's a 2500, but for the price I was not going to let it pass by last summer. spring swap or any idea's, I dont haul anything of weight with it.... thanks
Old Apr 20, 2010 | 6:17 PM
old dog's Avatar
Default rough ride
there is not a lot you can do it's a work truck ,but you can drop a leaf out of each rear spring and put some monroe sensa trac shock's they ride good ! if you need the capicity back rear air bag's added will bring it back .
Old Apr 20, 2010 | 6:25 PM
nauticstar87's Avatar
Springs from a 88-98 1500 will swap. But I don't think the ride os that much different between the 2. Dropping a leaf outta each side doesn't sound like a bad idea. Just make sure the u-bolts are good.
Old Apr 20, 2010 | 7:58 PM
MDTAHOE's Avatar
Professional Mechanic
The best option would be 1500 leaf springs and shocks.
Old Apr 21, 2010 | 6:06 PM
thank you..i will consider that. just desiding on weather it is worth it or not. I use it manly for the road when traveling....
Old Apr 21, 2010 | 6:22 PM
MDTAHOE's Avatar
You could probably get it all used for under 200. And replace it all in a few hours.
Evan III
14
Oct 12, 2023 3:04 PM
ActiveMonkey
Mar 9, 2009 9:36 AM
lawsona
Jun 25, 2008 7:51 PM
lawsona
Jun 25, 2008 5:30 PM
turbinesurgeon
May 20, 2006 6:35 PM
