Leaking water and can't find the source
Old Mar 12, 2013 | 5:57 PM
Ericraymond's Avatar
Default Leaking water and can't find the source
I have a 1994 4.3l c1500 single cad reg bed 2wd with 212k and its leaking water under the truck look to be where the tranny meets the block. I had someone look at it and said it was the intake manifold. So I change the gaskets and it fixed it for about 5 day no leaks. Then it started again. It leaks when the truck is off to a real fast leak. I think it might be the real plugs and I pulled the starter and their was water that came down on me when I removed it. None of the freeze plugs I can see are leaking. Is their and hidden if I pull the tranny?
Old Mar 12, 2013 | 6:40 PM
kevinkpk's Avatar
I take it you are loosing anti-freeze. Yes there should be freeze plugs on that end of the engine
Old Mar 12, 2013 | 8:25 PM
Is it near the top of the block or the bottom where I could pull the tranny to get them?
Old Mar 12, 2013 | 9:15 PM
hicksvilleshick's Avatar
Yes.
after you get the tranny off you should see them, can't remember how many on the back of those 4.3 blocks.
Old Mar 12, 2013 | 10:56 PM
Ok thanks. Ill start pulling the tranny tomorrow
karlall90
Sep 25, 2013 10:43 PM
scumpoozie
Jun 10, 2013 7:19 AM
TRUCKDIVA
Jun 6, 2013 2:26 PM
biglg
Jan 28, 2008 8:26 PM
guvner
Nov 12, 2007 7:22 PM
