Left turn signal acts like hazards
04 Silverado has issue with the left turn signal acting like hazards are on - the right signal operates correctly. Any suggestions?
Fixitjamie (August 24th, 2021)
Well I've checked everything but the flasher module to no avail. Is there a way to check that or suck it up and dish out the cash and pray it fixes it?
do you have a part # for that by chance? I’m having the same exact issue, changed tail lights, tail light wiring changed the circuit board in the back, check all the fuses and even ran through some grounds. When the head lights are off the brake lights work fine and the blinkers do the same thing, but when I turn the head lights on the blinkers won’t work proper they actually make the reverse lights flash as well and the left brake light won’t work.
[QUOTE=Darwin Connell;463330]do you have a part # for that by chance? I’m having the same exact issue, changed tail lights, tail light wiring changed the circuit board in the back, check all the fuses and even ran through some grounds. When the head lights are off the brake lights work fine and the blinkers do the same thing, but when I turn the head lights on the blinkers won’t work proper they actually make the reverse lights flash as well and the left brake light won’t work.[/QUOTE
part number GM 10383321 from Amazon. It's around $60. Super easy to replace.
