Left turn signal acts like hazards
Old May 8, 2010 | 5:44 PM
Jakester's Avatar
Default Left turn signal acts like hazards
04 Silverado has issue with the left turn signal acting like hazards are on - the right signal operates correctly. Any suggestions?
Old May 8, 2010 | 7:50 PM
desrtrat's Avatar
check/replace left side bulbs. sounds like one of the filaments is broken, and making contact with the outer. has happened to a lot of people.
good luck
Old May 8, 2010 | 8:48 PM
Mille Racer 69's Avatar
happend to me, brake light was out
Old May 9, 2010 | 5:47 AM
Jakester's Avatar
Will check these - thanks for the info!
Old May 9, 2010 | 9:01 AM
brewe's Avatar
15 Year Member
I had same problem and it was the flasher module on back of the fuse pnl. $119 dollars later it was fixed.
Old May 13, 2010 | 4:23 PM
Jakester's Avatar
Well I've checked everything but the flasher module to no avail. Is there a way to check that or suck it up and dish out the cash and pray it fixes it?
Old Feb 25, 2021 | 8:23 AM
Isaiah Larson's Avatar
Default 03 chevy
So I have a similar issue except it’s the right side engages the hazards but my left turn signal works fine , and it does it randomly. 03 Chevy Silverado 1500
Old Apr 8, 2021 | 7:40 AM
Girlsliketrucks's Avatar
Default Same
I'm having the same problem but my left and right are going crazy and my front and tail light all work.
Old Apr 9, 2021 | 2:00 PM
Darwin Connell's Avatar
do you have a part # for that by chance? I’m having the same exact issue, changed tail lights, tail light wiring changed the circuit board in the back, check all the fuses and even ran through some grounds. When the head lights are off the brake lights work fine and the blinkers do the same thing, but when I turn the head lights on the blinkers won’t work proper they actually make the reverse lights flash as well and the left brake light won’t work.
Old Aug 24, 2021 | 3:13 PM
Fixitjamie's Avatar
Default Turn signal turns on hazzards
[QUOTE=Darwin Connell;463330]do you have a part # for that by chance? I’m having the same exact issue, changed tail lights, tail light wiring changed the circuit board in the back, check all the fuses and even ran through some grounds. When the head lights are off the brake lights work fine and the blinkers do the same thing, but when I turn the head lights on the blinkers won’t work proper they actually make the reverse lights flash as well and the left brake light won’t work.[/QUOTE
part number GM 10383321 from Amazon. It's around $60. Super easy to replace.
